When jumping to a cue point, it jumps as you hit the key. Can it be synchronised so it waits for the start of the next bar, to make it seamless?
geposted Sun 15 Jan 17 @ 2:50 pm
action_deck 1 ? repeat_start_instant "ISBGP" 33ms & deck 2 param_bigger get_beat_bar 0.026 ? deck 1 hot_cue 1 & repeat_stop "ISBGP" : deck 2 param_smaller get_beat_bar 0.974 ? deck 1 hot_cue 1 & repeat_stop "ISBGP" : nothing : repeat_start_instant "ISBGP" 33ms & deck 1 param_bigger get_beat_bar 0.026 ? deck 2 hot_cue 1 & repeat_stop "ISBGP" : deck 1 param_smaller get_beat_bar 0.974 ? deck 2 hot_cue 1 & repeat_stop "ISBGP" : nothing
geposted Sun 15 Jan 17 @ 4:44 pm
@3*X-rated, can you have a try of this, change hot_cue 1 [4 instances] to play, see if it will suit remix decks.
geposted Sun 15 Jan 17 @ 4:51 pm
Sorry, very new to this stuff. Could you give a bit more detail please? Many thanks...
geposted Sun 15 Jan 17 @ 5:14 pm
Just enable "smart_cue" option and then use your hotcue buttons.
The jumps between hotcues will follow the track's grid.
PS: By default the jumps between hotcues are quantized to 1 beat when you use the "smart_cue" option.
You can change that by changing the "globalQuantize" option on VirtualDj settings. Therefore you can set it to quantize to half beat, or even to a quarter of a beat
geposted Sun 15 Jan 17 @ 9:34 pm
Or (I believe) to 4 if you really want to wait for the next bar (if it is a 4/4 track)
geposted Mon 16 Jan 17 @ 10:33 am
Quantize doesn't wait to start though, quantize might do what the user wants. Although I can see
A quantized delayed start opens up options.
geposted Mon 16 Jan 17 @ 10:56 am
Quantize not, but the SmartCue does wait.
geposted Mon 16 Jan 17 @ 10:58 am
Does it,? I thought it just matched phase, I'll have to test, how about whilst playing?
geposted Mon 16 Jan 17 @ 11:28 am
It doesn't wait, it just jumps immediately, but quantized (so a little before the cue point if you press too early)
geposted Mon 16 Jan 17 @ 11:39 am
Thanks for the replies. Have enabled as per instructions and is certainly better than it was.
geposted Mon 16 Jan 17 @ 7:00 pm
