Hello,
Since the mic on/off is currently on a switch, I was wondering if I can assign a button to mute the microphone?
I have a Shure that is plugged into the back of the unit and have not configured any audio for the mic at all.
Is this a possibility? If so, what do I have to do?
Thanks
Thanks
geposted Thu 19 Jan 17 @ 9:50 pm
I believe the mic channel is an analog hardware channel. Meaning it is not able to send or receive Midi messages and therefore can not be controlled by VDJ.
geposted Fri 20 Jan 17 @ 10:48 am
As PachN said, the Microphone section on DDJ-SZ is completely hardware (as the rest of the mixer)
You cannot control the MIC section through the software. You can only control it through the switch on top of the DDJ-SZ MIC section.
geposted Fri 20 Jan 17 @ 2:09 pm
