So I picked up a couple cdj's, and I was wondering what time code CD's you all are using, Serato or VDJ?
The reason I ask this, is because I use Serato time code vinyls as many here do.
So any input would be appreciated.
geposted Sat 21 Jan 17 @ 11:46 pm
They are both fine.
I use both CDJ's and turntables and have both VDJ and Serato timecodes.
There really is no difference in my opinion.
geposted Sun 22 Jan 17 @ 12:42 am
Thank you sir
geposted Sun 22 Jan 17 @ 4:51 am
Actually how are the Traktor timecodes? I was wondering if the 2khz code tracked better.
geposted Sun 22 Jan 17 @ 5:03 am
wats up djz
geposted Wed 19 Apr 17 @ 8:56 pm
Really, any timecode standard should make no difference, but the devs aren't perfect, vdj supports all dvs so if you find fault sayso.
geposted Wed 19 Apr 17 @ 9:38 pm
im going try dat
geposted Wed 19 Apr 17 @ 11:13 pm
