I had an issue last night with PitchLock not staying active...
Kept setting it to "yes" in options, and with a song or two, it resets itself to "no".
Any ideas what's going on?
geposted Sun 22 Jan 17 @ 12:24 am
didn't you ask for a script not a few days ago that turned pitchlock off?
geposted Sun 22 Jan 17 @ 12:34 am
Having the same issue.... I talked to the staff and they told me it was a feature, because it can screw with people's mixing or something.. (I wish they would fix it to work like it should..)
geposted Sun 22 Jan 17 @ 6:52 pm
So what should happen then if you load 2 tracks with bpm's very far apart?
Would it really be your intention to match them anyway to keep pitchlock on?
Or keep pitchlock on even though the bpm's don't match?
geposted Mon 23 Jan 17 @ 4:49 am
me gusta mucho virtual dj 8 pero q lastima q no puedo odtener la lisencia tanto q lo e rogado pero ya esta bueno al unico q hay q rogarle es a dios con dios todo sin el nada grasias
geposted Mon 23 Jan 17 @ 6:10 pm
Por favor, intente nuestro foro espanol aqui, gracias.
geposted Mon 23 Jan 17 @ 8:16 pm
