When I load a new song, the first thing I do is delete all the default POI markers. Is there any way to save this as the default setting, ie, when I load a new song there are NO markers. Hope that makes sense.....
geposted Sat 28 Jan 17 @ 11:59 am
why do you do this?
geposted Sat 28 Jan 17 @ 12:27 pm
Keeps the POI editor cleaner and easier to use
geposted Sat 28 Jan 17 @ 1:31 pm
just uncheck show all ... all you will see is the cue points you set :-)
geposted Sat 28 Jan 17 @ 2:05 pm
what do you do this?
geposted Sat 28 Jan 17 @ 2:12 pm
Thanks WickedMix
"just uncheck show all ... all you will see is the cue points you set :-)"
It really was as simple as that!!
geposted Sat 28 Jan 17 @ 3:35 pm
