Hello I'm John.(VDJ Home User). I have a simple question please if you know on-how to connect "Broadcast" - PC-To-PC Direct. Then if i start broadcast then finish then me looking on my "Broadcast" it says John Ray 2K is not broadcasting right now. That's a problem. Someones can help this on how to fix it out.
geposted Tue 31 Jan 17 @ 4:44 am
If you've finished your broadcast you are not boadcasting.
Or am I wrong?
Or am I wrong?
geposted Tue 31 Jan 17 @ 8:10 am
Your not wrong the problem is my broadcast can't upload or saved in my sets. That's the problem sir sorry.
geposted Tue 31 Jan 17 @ 8:17 am
I think you have to use Podcast, not Broadcast.
geposted Tue 31 Jan 17 @ 8:27 am
ok sir i'll try now then test the upload. Thanks sir to advice but now i'll try if it works. :)
geposted Mon 06 Feb 17 @ 2:03 pm
