Helped out another user [kevilev] with a script, probably suits dancehall type genres or anything where a reload is suitable.
It works really well so I figured I'd share it.
Looks complicated but a single press copies the current track to the other deck, calls hotcue 1 on the copy and loops out the original
it's just a bit lengthy due to bomb proofing [dealing with slip_mode, making sure it works right everytime]
if you want this breaking down into english to understand what is doing what just ask as I've got it save in a message.
enjoy
crossfader 50% & action_deck 1 ? deck 2 slip_mode ? deck 1 repeat_start_instant "SMB1" 33ms 2 & deck 1 var "smbDoOnce" 0 ? deck 2 slip_mode 0 & deck 1 set "smbDoOnce" 1 : deck 1 clone_deck 2 & deck 2 hot_cue 1 & deck 2 sync & deck 1 effect_active "loop out" & deck 1 eq_low 0% & deck 2 slip_mode 1 & deck 1 set "smbDoOnce" 0 : deck 1 clone_deck 2 & deck 2 hot_cue 1 & deck 2 sync & deck 1 effect_active "loop out" & deck 1 eq_low 0% : deck 1 slip_mode ? deck 2 repeat_start_instant "SMB2" 33ms 2 & deck 2 var "smbDoOnce" 0 ? deck 1 slip_mode 0 & deck 2 set "smbDoOnce" 1 : deck 2 clone_deck 1 & deck 1 hot_cue 1 & deck 1 sync & deck 2 effect_active "loop out" & deck 2 eq_low 0% & deck 1 slip_mode 1 & deck 2 set "smbDoOnce" 0 : deck 2 clone_deck 1 & deck 1 hot_cue 1 & deck 1 sync & deck 2 effect_active "loop out" & deck 2 eq_low 0%
enjoy
geposted Tue 31 Jan 17 @ 5:14 pm
Oooooh me likes.
geposted Tue 31 Jan 17 @ 9:54 pm
