Hi guys
I know how to burn a mix cd with seperate tracks when I use the split-audio option but is there a way to burn a cd with the wav and cue file created in virtual dj without having to break up my original wav file into separate tracks. I want to keep my original wav mix as one file.
Whats everyone using. I looked at audacity and nero and even Soundforge/CD Architect but I believe all of these softwares still split the wave file into separate audio files.
Thanks in Advance
DJ Dusty
Thanks in Advance
DJ Dusty
geposted Sun 05 Feb 17 @ 11:32 pm
I've always used Nero Burning ROM,
Just load in your file as if you are burning it as a single track, right click and go to properties, there should be a splits tab, you can just click in the waveform and add and remove splits where ever you like (you can preview it here too so placement can be exactly where you like). Be sure to make sure you have 0 second gaps.
Been using this techniques for about 15 years, to this day haven't found a better way (not that i looked much)
Good luck
Good luck
geposted Mon 06 Feb 17 @ 5:25 am
