Topic: How to implement new Effects in VDJ 7.0.5 Pro
Hi @all,
hopefully someone can help me.
I'm running a Virtual DJ 7.0.5 PRO Version and I'm able to download Effects from (https://virtualdj.com/addons/effects.html), but I'm not able to get them working or better to say "visible" in VDJ ?
Two things:
1.) VDJ is running on my Windows 10 Laptop with GERMAN operating system
2.) When I download the files, they are coming as *.vdj files
I've searched my Laptop for the already present Effects and found them here: C:\Users\MyName\Documents\VirtualDJ\Plugins\SoundEffect, but there are only .dll and .ini files.
How can I get my recently downloaded effects working ? Simply copying the *.vdj Files and restart VDJ doesn't seem to work. What did I wrong ?
Thanks in advance
Michael
geposted Fri 10 Feb 17 @ 9:41 am
Double click the files you downloaded in order to install them!
And they don't save as .vdj files. They should save as .exe (executable) files.
Unless you're trying to downlad samples, which in that case you should copy them on your sampler folder and load them on the sampler area of the browser
I did, but nothing happen.
It works perfect with downloaded skins, but not with effects.
f.e. I loaded "candy on the dancefloor.vdj" but can't find them in the effects section, neither in "Sound Effects" nor in "Others"
any additional ideas ?
Michael
That's because .vdj files are samples. Please read the reply above again.
OMG; How could I have been so blind.... SORRY - you're absolutely right.
It works - Topic closed
Hi guys, I just bought licence and wrote down the wrong email adress, I forgot one letter...
I need VDJ for tonight and suport help is very slow. Can somebody help me?
Only support guys can help you fix this issue. Just be patient. Usually they respond very fast.
