I have modes setup for my most used pads. Actually this script was written before the Pad Page feature was added. So Im trying to use the enconder to scroll throouh the pages, which i use this script - Pad_page +1 - but the problem is when using the encoder to scroll the pages, the pads are not working, but if i use the mode buttons they work as normal. Here is a sample of the script from 1st mode button and 1 performance pad.
Mode 1 - set 'mode' 0 & pad_page 'hotcues'
Performance Pad 1 - var_equal 'mode' 1 ? loop_in : var_equal 'mode' 2 ? sampler_pad 1 play_stutter : var_equal 'mode' 3 ? slicer 1 : var_equal 'mode' 0 ? shift ? delete_cue 1 : hot_cue 1 : nothing
what is missing in the script.
geposted Mon 13 Feb 17 @ 4:28 pm
Your mapping is pre pad pages
change all your pads to
pad X
[1 to 8]
change all your shift+pad mappings to
shift_pad X
your encoder script should be
param_bigger 0 ? pad_page +1 : pad_page -1
link your mode buttons directly to a correct pad page
pad_page 'hotcues'
if you only use 8 pad pages then direct linking is fine if you use more than 8 I recommend making an index pad page [a pad page to call other pad pages]
pad X
[1 to 8]
shift_pad X
pad_page 'hotcues'
geposted Mon 13 Feb 17 @ 9:46 pm
pad X
[1 to 8]
shift_pad X
pad X
[1 to 8]
shift_pad X
can you use the sample to show me what you mean
pad_page 'hotcues'
pad_page 'hotcues'
geposted Tue 14 Feb 17 @ 12:43 am
<map value="Performance Pad 1" action="pad 1" />
geposted Tue 14 Feb 17 @ 12:50 am
will this handle the shift + pad for the delete functions
geposted Tue 14 Feb 17 @ 12:53 am
pad X
[1 to 8]
shift_pad X
pad X
[1 to 8]
shift_pad X
pad_page 'hotcues'
pad_page 'hotcues'
After multiples readings I think im getting it now...
geposted Tue 14 Feb 17 @ 1:14 am
the mode L.E.D...."var_equal 'pad_page' freeze slicer ? on : off"
not working, always on
The pad l.e.d.
var_equal 'mode' 1 ? loop_in : var_equal 'mode' 2 ? sampler_pad 1 : var_equal 'mode' 3 ? slicer 1 : var_equal 'mode' 0 ? hot_cue 1 : off
none working
The pad l.e.d.
none working
geposted Tue 14 Feb 17 @ 1:34 am
For leds use the same script: pad 1
geposted Tue 14 Feb 17 @ 10:59 am
not working, always off
the mode led isnt working always off
geposted Tue 14 Feb 17 @ 5:48 pm
See the default mapping for your HW, the led mapping should tell you enough for you to figure it
Honestly as a long time user, you should at least get why your mapping isn't working even if you don't know what is needed to make it work.
You should try keyboard only mixing, just in practice time, even if it's pretty mediocre mixing, keyboard only forces you to get it.
geposted Tue 14 Feb 17 @ 6:14 pm
<map value="LED_PAD_MODE_HOTCUE" action="pad_page 'hotcues' " />
<map value="LED_PAD_MODE_WHATEVER" action="pad_page 'freeze slicer' " />
PS: "Freeze Slicer" is not a default pad page. I assume you have created / downloaded such a pad page, correct ?
geposted Tue 14 Feb 17 @ 6:33 pm
freeze slicer is just the slicer with a loop 8
geposted Wed 15 Feb 17 @ 3:29 am
Ive never been able to understand VDJ script I look and study it but i just dont get it....And before i come here I try what i can...but i just dont get it...
geposted Wed 15 Feb 17 @ 3:32 am
ok my quotation is on the wrong words
geposted Wed 15 Feb 17 @ 3:35 am
