I am interested in buying the DDJ-SP1 to use it alongside my mixtrack pro 3 controller.
Can I program all the buttons and knobs on the pad to do whatever I want them to?
Thank you!
Thank you!
geposted Wed 01 Mar 17 @ 9:42 am
If you have the programming skills then yes. Your current controller license though will probably not permit the use though so you may need to upgrade it to pro, or get second controller license for the SP1
geposted Wed 01 Mar 17 @ 9:50 am
The SP1 is totally configurable (but you do need some knowledge of mapping code), one of the best pieces of additional kit you can buy.
As above, you will need a Pro or Pro subscriber licence to use both controllers at the same time.
geposted Wed 01 Mar 17 @ 9:53 am
Thank you for the quick response!
geposted Wed 01 Mar 17 @ 10:12 am
