When i use an sample added by me .wav, (only in this case), vdj 8.2 b3621 pro infinity stops unespectedly and hear strange sounds: https://youtu.be/UHkRu5bg9rs Previous versions of VDJ was t doing so. I use dell xps: I7 processor, ram16gb, 2gb video memory...Pioneer ddj-rr controller...windows 7. Does anyone know how to solve this issue? Thanks!
geposted Sun 05 Mar 17 @ 8:32 am
You say that "previous versions" of VDJ played the WAV. Which versions? VDJ 7? VDJ 8? Which builds?
Does the WAV play when loaded to a deck?
geposted Sun 05 Mar 17 @ 9:37 am
I noticed this problem after the last update but I'm not sure it's a vdj bug, It appeared to me still a signature error, ntdll.dll file
geposted Sun 05 Mar 17 @ 9:54 am
this error occur only when play sample in vdj or press controller pad, when play the .wav sample on deck, run normally
geposted Sun 05 Mar 17 @ 10:07 am
Can you upload the wav sample and provide us the link ? Use PM if you don't want to share it here
geposted Sun 05 Mar 17 @ 3:05 pm
I think it s solved! I just deleted all samples from records folder and i ve put them back. Now it seems to work properly. Pobably i have removed some root (path)...anyway...thank you very much!
geposted Sun 05 Mar 17 @ 5:05 pm
...some news... the same problem when i set sample to "pitched" (sample editor - drop - pitched). If it is set to "flat" than run properly.
geposted Sun 05 Mar 17 @ 5:32 pm
