I'M NOT ABLE TO LOG IN WHILE IN USING THE PROGRAM . IT KEEPS TELLING ME " CAN NOT CONNECT TO VIRTUALDJ SERVERS. SO, I CAN'T RUN THE FULL VERSION. PLEASE HELP
geposted Fri 10 Mar 17 @ 4:58 am
I'M NOT ABLE TO LOG IN WHILE IN USING THE PROGRAM . IT KEEPS TELLING ME " CAN NOT CONNECT TO VIRTUALDJ SERVERS. SO, I CAN'T RUN THE FULL VERSION. I DEFINATELY HAVE INTERNET CONNCECTION . I CAN LOG IN VIRTUAL DJ WEBSITE VIA MOZILLA PLEASE HELP
geposted Fri 10 Mar 17 @ 5:01 am
HAVE YOU USED A CRACKED VERSION? IT MAY HAVE MODIFIED YOUR HOSTS FILE.
geposted Fri 10 Mar 17 @ 7:32 am
geposted Fri 10 Mar 17 @ 8:52 am
djdad wrote :
thanks that worked out great , i really appreciate the tip :)
geposted Fri 10 Mar 17 @ 1:17 pm
hey anyone plz help.Ive been gone for a while and now i cant use virtual for my radio shows any more? whats up? ive always done it so easily for my radio show. I just used a usb board for a counsel. so mixer straight to usb,but it says virtual dj doesn't have a sound card. i never had this problem before. Im so sad !!! anyone can you suggest??
geposted Fri 10 Mar 17 @ 6:38 pm
Can't suggest anything with the very limited information you have given, that's for sure.
geposted Fri 10 Mar 17 @ 6:39 pm
