Does the Skin Creator tool still create skins for v8.2? Not the skinbuilderv3.
geposted Sun 12 Mar 17 @ 11:04 pm
The skin creator tool from jeremieleroy doesn't seem to work anymore. I just tried to download the version on his site and it doesn't load any of the default VDJ 8.2 xml files. If you try to start with an image, it loads the image but still has a problem loading the xml.
Gives the error "Unable to open that file, please try again. Error code = OpenFile"
geposted Tue 14 Mar 17 @ 12:38 am
I don't believe the skin creator was ever updated to work with v8
geposted Tue 14 Mar 17 @ 12:40 am
