Using my backup machine which is a desktop, with 16g of RAM. Getting this message that I don't have enough memory, and the track loads, but does not play. What can I do? Win 10.
Had to go to my backup to the backup, Exit VDJ but did not reboot.
geposted Tue 14 Mar 17 @ 2:05 am
You only need 3gb's..something is badly wrong.
You're cpu is vastly more important.
Get the Windows performance monitor going.
Drop back to an older version on VDJ, especially if you're on a beta.
Reinstall all the related software.
Get all the latest Windows updates (suspect.. but Microsoft have won my admiration recently).
I repeat again 16gb's is way over what Win 10, and VDJ 8.2 need.
Use a process of elimination starting with shutting down you're internet connection.
One of your open websites might be rogue?
The likes of Spotify Pro (not the new VDJ plugin) and Amazonmp3 are well well designed.
I give them +1.
I give them +1.
geposted Tue 14 Mar 17 @ 10:33 pm
I think you have faulty memory.
You probably have two 8gb modules, remove each in turn and restart systematically.
Do a memory check.
Just.. hunt the problem down!
Do a memory check.
geposted Tue 14 Mar 17 @ 11:52 pm
