Hoping someone can help.
I have used a Pioneer DDJ-SP1 with DJ8 for some time and it works great. I recently added myDMX 3.0 to the mix and I am now having issues. I trigger myDMX using Loopbe and everything is fine. I can also use the DDJ absolutely fine. I can't use both at the same time.
It is like a driver conflict issue I think. If I set up myDMX first then that works great but the DDJ will not. If I set up the DDJ first the myDMX claims the rights to the DDJ away from VDJ. VDJ reports that the DDJ failed to connect.
I have gone through, what I think is, every possible set up option and there is no issue there. It's just they won't work at the same time.
Has anybody else had this and how did you get them to work?
geposted Fri 17 Mar 17 @ 7:14 pm
Probably a silly question, but why is LoopBe necessary to install and use in order to run myDMX application ? Or is this a way to use DDJ-SP1 (or other hardware) to control myDMX ?
geposted Fri 17 Mar 17 @ 9:42 pm
Sorry for being lat to respond, I didn't get am email letting me know you had posted.
LoopBe is used to trigger audio bpm in myDMX.
geposted Mon 20 Mar 17 @ 5:56 pm
