Hi everyone, I just bought a Numark Mixtrack 3 today and I have been messing around with it on Virtual DJ, but for some reason my 2nd deck doesn't play on virtual dj. The turntable spins on Virtual DJ, there is just no sound output. Im also still on the free version. Thanks!
geposted Sat 01 Apr 17 @ 12:44 am
You mean you cant control Deck 2 with your Mixtrack 3, or no sound coming out from that deck ?
Which sound card are you using, how are your connections done and what do you have in Audio setup in VirtualDJ ?
geposted Sat 01 Apr 17 @ 1:00 am
No sound coming from the deck, the 2nd deck works fine just no sound comes from it. I am just using the internal sound card from my computer.
geposted Sat 01 Apr 17 @ 1:11 am
Ahhh I just figured it out, my channels were messed up. Thank you for the response!
geposted Sat 01 Apr 17 @ 1:14 am
