I ordered 2 reloop neons. My question is can i map pad page to it, to work independent of the pad pages on my mixer? It has 4 mode buttons which will switch the 4 assigned pages. While still being able to select pages on my mixers 8x8 pad grid.
geposted Sat 01 Apr 17 @ 5:14 pm
Whatever pad page you map the Neon Pad mode buttons to select, the same Pad page will be loaded on your other "main" controller (whatever you use). There can only be one Pad page selected per deck.
So there is no easy way to have e.g. Hotcues on your main controller and Loops on the Neon. If you want it that way, you will need to use variables for the Pad mode buttons and "original" actions like hot_cue X or loop X instead of pad X
geposted Sat 01 Apr 17 @ 6:41 pm
well guess ill send them back...no use then...
geposted Sat 01 Apr 17 @ 10:00 pm
Hold on, you can script the neon to call whatever padpage when ever.
A var or two and some queries and it's all gravy.
I've just aqurierd a pair myself so tripleX you're in luck.
I'm sure I can bespoke something here.
geposted Sat 01 Apr 17 @ 11:05 pm
Will it affect the pad pages I have chosen on the vci400 pads...or the Pioneer S9 pads. the only reason im getting them is to have extra pad pages functions and hopefully to trigger remix decks(if that project is finished)...or for tratkors remix decks.
geposted Sun 02 Apr 17 @ 7:50 am
Well pad pages only call script so you could add that script direct to the neon, or you could on neon button press, query the current page switch to the page correct for the neon perform the pad action and switch back.
geposted Sun 02 Apr 17 @ 9:00 am
That what I would do. Simply bypass the Pad Pages on the NEONs and call the actual functions, like we did before Pad Pages were introduced in VDJ 8.2 - and then let the Pad Pages be handled by your mixer/controller
geposted Sun 02 Apr 17 @ 9:24 am
Ok i get what you guys are saying. Loco Ill be bugging you again...also about them remix decks/loop sampler...Gonna need ya
geposted Mon 03 Apr 17 @ 1:51 am
