HI, Can anybody help with the script of saving a loop to the recording bank and saving the actual position to the sampler pad using my apc mini. IE Row 5 and Col 6. The default scripting works as such but only saves to the next available slot
geposted Sun 02 Apr 17 @ 11:51 am
you have tried pushing record plus the slot at the same time?
because its working here on my apc mini that way.
also make sure you are running the latest build of VDJ because there were some changes in one of the current builds to the mapper.
I am on build 3671 if that helps.
geposted Sun 02 Apr 17 @ 12:51 pm
Hi yes, just tried again and It just adds to the next available free slot.
var '$sampleedit' ? sampler_edit 37 : var '$samplemute' ? sampler_mute 37 : var '$samplerec' ? sampler_rec 37 : shift ? sampler_stop 37 : sampler_pad 37
this is the button command
geposted Mon 03 Apr 17 @ 10:12 am
