I moved from vdj 7 to 8 and all my hot cue's moved a bit left, is there a way to fix all the cue's back ?
geposted Thu 20 Apr 17 @ 1:15 am
Map a button as ..
shift_all_cues +122ms
and use that each time you see a track with shifted cues. The 122 value (in milli-seconds) is just an example. Calculate the value using the Elapsed/Remain time from where the Cue is and where it should be.
geposted Thu 20 Apr 17 @ 1:23 am
Thank you i will try that !
geposted Thu 20 Apr 17 @ 1:38 am
