Hello, when I record a sample from the deck 1 or 2 it but in a slot, my question is the following would it be possible to make a macro on a button of my controller so that the last sample it launches from my controller The problem is that I have pads on my controller is it ia already samples on it, is me I want it to be the last sample live recording that it launches via this pad or button voila by thanking you in advance see you soon.
geposted Thu 20 Apr 17 @ 11:47 am
Hello I return to you for my worry now it works, enfaite to trigger the last sample in question on my controller denon mc8000
You have to save the sample is via the select load (holding? Unload: browser_enter) button, the last sample it is voila for the one who will want the combine thanks soon.
geposted Tue 02 May 17 @ 2:44 pm
