Hi there im wondering if anyone could help, i use virtual dj 8 and pay monthly for content unlimited but when i am out at a gig and get asked for something that is not on my Database i type song into search bar but it doesnt search. Now i have tryed making sure song title is spelt right and my internet connection is strong so ran out of ideas, so if anyone has any ideas where i am going wrong that would be great thanks
Mark
Mark
geposted Mon 24 Apr 17 @ 10:54 pm
Mark. If you are out at a gig, then you should have a pro license.
geposted Mon 24 Apr 17 @ 10:59 pm
ok, but would that help with the search problems?
Didnt get pro licence because i only do the odd party or fundraiser so dont do it full time!!
geposted Mon 24 Apr 17 @ 11:13 pm
Are you using Wifi/Ethernet or some 3G hotspot device to connect at your gig ? Perhaps there is some firewall or similar blocking/restriction in the connection you are using.
geposted Tue 25 Apr 17 @ 1:13 am
Maybe you're just searching for songs that aren't in Content unlimited? Or does it work well at home?
geposted Tue 25 Apr 17 @ 9:35 am
Thanks for your reply guys i will look into the firewall or some kind of restriction as i use my mobile phone 4G hotspot to connect too. I cant see it being tunes not on content unlimited as its just the odd chart songs that are not on my database that probably should be on lol.
Thanks again guys
Thanks again guys
geposted Tue 25 Apr 17 @ 10:03 pm
I have seen a few other posts about this recently, so seems there could be some sort of glitch somewhere.
https://virtualdj.com/forums/217381/VirtualDJ_8_2_Technical_Support/Spotify_search_not_working_.html
They seem to be having the same problem, have you tried a different network connection?
geposted Tue 25 Apr 17 @ 10:12 pm
