I have several external drives with several different folders...I want to merge them together and remove the duplicates...what software do you guys use? I tried MusicBrainzPicard but it crashes and is not very user friendly.
geposted Mon 24 Apr 17 @ 11:12 pm
if you don't want to loose your cues or have to re-analyze i suggest you do the merging with VDJ
geposted Mon 24 Apr 17 @ 11:56 pm
MediaMonkey
geposted Tue 25 Apr 17 @ 7:59 pm
What @wickedmix said or you could recurse them all in VDJ, then sort by name and delete the versions you've never played. Whichever method you use it'll still take for*%@#+?~ever
geposted Wed 26 Apr 17 @ 2:10 pm
MediaMonkey.
geposted Wed 26 Apr 17 @ 11:15 pm
