how do i get both of my pa speakers from buzzing i have i have it connected to a male xlr to a quarter inch idk if that is the problem please help thank you fellow Dj's :)
geposted Tue 25 Apr 17 @ 4:46 pm
Might need to give a bit more info, what speakers? what exactly are they connected to the other end? a controller or audio interface? normally caused by ground loop hum, but dont normally get that with balanced xlr/jack cables. do your speakers have a ground lift button? lots of questions unless you give more info
geposted Tue 25 Apr 17 @ 4:55 pm
Do you have a laptop? Try to disconnect the power cord.
geposted Tue 25 Apr 17 @ 5:12 pm
You will need ground loop isolators (Google it)
geposted Tue 25 Apr 17 @ 6:10 pm
