Hello I just experienced a crash with the latest build, a message popped up with decompression.... saying how much memory is available then it crashed. My system has 16 gb of ram... I installed the build half hour ago then ran recurse to pull in my new songs, then I've been sampling the new songs when it happened. Will try to figure out how to go back a build for tonight's gig.
geposted Tue 25 Apr 17 @ 5:17 pm
Older builds are here:
https://virtualdj.com/download/build.html
Make sure you validate that the build is correct after install (settings window bottom left)
geposted Tue 25 Apr 17 @ 5:23 pm
Thank you, I was not able to locate it even though I searched all over the site, I had to find it with google. They should make it easier, maybe an option built within vdj, thinking what would happen if I was already on the road.
geposted Tue 25 Apr 17 @ 5:28 pm
Have requested a link to older builds on the forum banner several times now but ignored.
geposted Tue 25 Apr 17 @ 5:36 pm
Which skin did you use when it crashed? Last crash report received is dated April 11, 2017
geposted Tue 25 Apr 17 @ 6:51 pm
I opened with the default skin and changed to SilverSleek 3 which I often use, after the crash I opened back VDJ and the default skin was back, also tracks that I was dropping on the sidelist did not save. Not sure why it crashed a few weeks ago but VDJ restarted itself. Today it did not restart.
geposted Tue 25 Apr 17 @ 7:06 pm
