found a bug...
on vers. v8.2.3678 i could route a mic input to a line in and add effect when line in was active on the deck.
this was the last build, that this would work on..
vers. v8.2.3696 let you route it, and activate it.. but no signal is comming through.
same with the latest early release.
PC with windows 10, and vdj pro.
geposted Thu 27 Apr 17 @ 11:13 am
Still working here. The mic works when activated from master panel?
geposted Thu 27 Apr 17 @ 11:24 am
not using master panel.
have 2 sound cards with mic inputs, assigned to a line in, so i could add it to deck 5 & 6, and add effects to them.
but the latest build and newest early, don't show any sounds in the meters no matter how much gain i throw in
geposted Thu 27 Apr 17 @ 12:07 pm
so what is the action you are using to assign the Mic as Line In to your Deck ?
I suppose something like ..
deck 5 linein 'mic'
, right ?
I just tried with a Input channel as Mic in Audio Setup.
Used the 6 decks default skin
assigned a custom button as deck 5 linein 'mic' (the LineIn button offered on Left deck does the same thing)
made deck 5 as left deck
enabled linein in Deck 5
enabled Echo effect on left deck (deck 5)
My voice got affected from the Echo Effect.
deck 5 linein 'mic'
, right ?
geposted Thu 27 Apr 17 @ 8:48 pm
don't know what the problem was. but nothing wrong with latest release..
geposted Wed 09 Aug 17 @ 4:55 pm
