I just bought the party mix controller, but I've been having problems getting audio through my headphones. I've looked everywhere and couldn't find an answer, was hoping I could find some help on the forums. I can hear static through the headphones, so I know a connection is being made, any help is appreciated.
Audio Settings -
Output: Speaker + Headphone (chan 1&2, 3&4)
Card: Two Soundcards
Input: (None)
I've been looking at setups for similar controllers and they generally have a card option for that controller, where as I only have the two soundcards option. I'm thinking this may be the issue, wondering if I missed a driver installation?
Update -
I've managed to get audio through the headphones, but i'm just getting the same audio that's being played through the speakers, the headphone buttons for each track don't affect anything.
My new settings are currently...
Output: Speaker + Headphone (master speakers (high definition audio device) (wasapi) chan 1&2
(Headphones - Party Mix (Wasapi) chan 3&4
Card: Two soundcards (Numark Party Mix is now available to me)
Input: (None)
Audio Settings -
Input: (None)
Update -
Input: (None)
geposted Sat 29 Apr 17 @ 5:15 pm
here is how the manual for that unit says to do it -> https://virtualdj.com/manuals/hardware/numark/partymix/advanced.html
also u might want to register your VDJ LE serial so u can get the updates .. the how to is in the manual as well
geposted Sat 29 Apr 17 @ 10:03 pm
If you get the Master Output properly, but not the Headphones channel, then maybe you need to set your Numark sound card to quadrophonic mode (4 speakers) from Windows Audio settings (Configure speakers).
geposted Sun 30 Apr 17 @ 3:07 pm
Thanks guys, I managed to get it working properly. I had to mess with the windows audio settings as said by djdad, and it turns out the cue mix nob needs to be turned all the way to left, not the right.
geposted Mon 01 May 17 @ 6:45 pm
Hi
Can you please let me know what the solution was? I am having the exact same problem!
I thank you in advance!
geposted Sun 07 May 17 @ 8:34 pm
I had a problem with headphones, but I will start to use "CUE MIX" right, now it´s all right..
geposted Thu 04 Jan 18 @ 4:56 pm
