So every once in awhile a song will sound like its skipping and I cannot figure out what the problem is , I can also hear this in my headphones .. I switched my whole controller and even my laptop and I am getting the same thing happening .. I have checked all my xlr cables also .. Only thing I have not checked yet is my QSC kw12 speakers any help would be great
geposted Sun 30 Apr 17 @ 12:31 pm
have you tried adjusting latency?
geposted Sun 30 Apr 17 @ 12:35 pm
I have the latency set to 512 and the ultralatency is set on yes
geposted Sun 30 Apr 17 @ 12:42 pm
sometimes turning off ultralatency helps
you could also try this free program to rule out latency http://www.resplendence.com/latencymon
geposted Sun 30 Apr 17 @ 12:47 pm
Think I have figured it out , looks like there was a surge in the laptop power adapter causing the problem ... I noticed that when I plugged it in that would say plugged in but not charging .. I have plugged in a good adapter , and its been working perfect knock on wood :]
geposted Mon 01 May 17 @ 12:47 pm
