Hello,
I have licence for my controler, but I tried second on Trial version. And now (after 30days) after 10min, i have annoucement about licence.... but I dont use that controler anymore...
But, after this anoucement pops up, my controler (with licence) works, but there is no sound at all.
geposted Mon 01 May 17 @ 11:31 am
Maybe the pop-up comes from an Audio configuration that is not allowed (e.g. Ext mixer setup) ?
Do you see any yellow-warning triangle in the Audio tab of VDJ settings ?
geposted Mon 01 May 17 @ 3:10 pm
Yeah, it was problem with Audio Options, I had to change it, and now it works :)
But now I have other problem.
When i set Audio options like on the screenshot, i cannot set Chan 1&2 for record (in my controler)....
And idea to fix that?
I use this set up for:
Deck 1 & 2 - normal
Deck 3 & 4 - for pre-listen mix on my headphones.
Deck 1 & 2 - normal
geposted Tue 02 May 17 @ 2:25 pm
