Topic: Saving Hotcues Possible?
Is there anyway to create a playlist with saved hotcue's for each song? New to Virutal DJ trying to figure out the best route to go for a few weddings I will be doing.
geposted Wed 03 May 17 @ 4:26 pm
Hotcues are saved to the database, if you want hotcues in different points for different playlists, make copies of the tracks.
Automix editor?
Okay I will try again I created hotcues saved then restarted virtual dj to see if they were still there but they were not.
Have you actually created HOT CUES and not temporary cues ?
VirtualDJ stores a hotcue ONLY if you press a hot cue button to store it.
If you have used the CUE button to store some cues these are temporary cues and they are not saved when you restart the software
