Hi. I've been on holiday and just returned to find nearly 300 tracks are gone from my cache. Have i missed something happening?
geposted Thu 11 May 17 @ 12:59 pm
Quick question trying to make sure that I'm understanding you right are the files
missing just from Virtual DJ. If so check the folder the files are in to
make sure there's not a file called (list or order) in the folder. For some reason if
you accidentally change your folders order in Virtual DJ this file is made. If
you find it delete it and all should be good.
geposted Thu 11 May 17 @ 3:41 pm
