i have the limited version and i did buy the unlimited audio but sometimes i get the full search and automix and then most of the time i do not why is this???
geposted Tue 16 May 17 @ 2:55 pm
probably depends on whether you are logged in or not with your LE License. You are listed here as a home user currently. If you are not connecting any hardware (controller or using external mixer mode) then best off keeping to home version.
EDIT - LE normally comes packaged with a controller, which gives you a limited feature license. otherwise you need some kind of full license to use a controller, which does also give you full functionality. You may have also got a trial period of the full pro with your controller, so you can see what it is like and tempt you into getting the full pro.
geposted Tue 16 May 17 @ 3:01 pm
Search is not available in Limited Edition except the case where the Content Unlimited folders are selected
Automix is not available in LE mode either. It will be (among all other Browser features) if the controller is not connected (VDJ is automatically set to "Home" mode)
geposted Tue 16 May 17 @ 6:23 pm
