I for the life of me cannot figure out how to load music from my itunes onto virtual dj. When I downloaded the software it initially loaded my library. since then I've added more songs on my itunes library, and would like to then Transfer it to my virtual dj but cannot figure out how to do so.
geposted Tue 30 May 17 @ 3:05 am
First thing you have to make sure that the tracks are actually physically downloaded by checking the iTunes folder in explorer/finder
Once they are downloaded, you can choose to view them using the iTunes folder in VDJ, and possibly clicking reload
If that still gives you problems, you can locate the files on the disk from within VDJ, and simply add them to your database like you would any other tracks on your disk
Personally I only use iTunes as a download program, and move the files to my own ordered locations as soon as they are downloaded, so that iTunes wont interfere with what I do
geposted Tue 30 May 17 @ 6:13 am
Make sure that iTunes allows the use of the Database with other programs
see here (in German language):
https://virtualdj.com/user/music234/blogs/5300/(Tipp)_Itunes_12_Kompatibilit__t_mit_VDJ.html
geposted Tue 30 May 17 @ 6:37 am
Scrap Itunes...research MediaMonkey
geposted Thu 01 Jun 17 @ 7:31 pm
