hi,
i have recently acquired a set of loops. there are 100 folders each containing 100 files with a total of 10,000 files. so adding and editing them 1 by 1 makes no sense.
after seeing what djdad did with the script to set colors to files based on their key, i figured maybe there is a way to do this the easy way.
please help me with the following scripts
i will select the folder, then button1, button2, etc. will each do the following.
1. create sampler bank based on "foldername"
2. add all the files in the folder to that specific sampler bank
this will save me allot of time.
i will select the files, then button1, button2, etc. will each do the following.
1. set all samplers to be loop > sync-lock
2. set all samplers [group] based on title(filename) less number.. example drumA1 [drumA] ..drumA2 [drumA] .. drumB2 [drumB]
geposted Sat 01 Jul 17 @ 2:37 am
Unfortunately, there is no action available to load a track to a sampler slot, so no script can be offered for this case.
geposted Mon 03 Jul 17 @ 10:08 am
thank you for the reply.
there have been some changes since i'v been working on this issue
i can bulk add tracks to a bank by simply selecting and dragging.
the images are captured from the file. so i use a tag editor to add images to the files. the title is captured from the file name, so i use the tag editor to bulk rename the files.
my current issues are..
creating a new bank based on folder name or at least renaming a bank based on a folder name via custom button script. unfortunately i have not found a way to rename a bank without scrolling up to the "list and advise"\ samplers \ right click bank and choose rename.
so a button to rename the slot would be nice..
a script that you (djdad) have done before for coloring tracks based on key.
go one by one and set all tracks to loop sync-lock
[*]button to set grouping.
truth be told i can easily create a c# program to do this if i only knew what and where the output should be.
i know how to read tags and file info in c# very quickly.
geposted Mon 03 Jul 17 @ 6:00 pm
dragging many songs to the sampler bank is easy enough. i just select, drag, drop.
it's the process of creating banks, renaming them, then setting sampler settings 1 by 1 that is very time consuming.
how about scripts to do the following.
== bank naming ==
== sampler setting ==
geposted Mon 03 Jul 17 @ 6:36 pm
No actions available to either name/rename/create Sampler Bank or batch-set samples to Sync mode.
Feel free to add all these in the Wishes Forum
geposted Tue 04 Jul 17 @ 3:37 am
