I have a deck that says "MUTE". There is no sound coming out of that deck. How do I clear that out?
geposted Mon 10 Jul 17 @ 2:27 am
deck X mute
But why is mute getting stuck?
geposted Mon 10 Jul 17 @ 8:11 am
Are you using a controller and have one of the midi channels set to another source?
geposted Mon 10 Jul 17 @ 8:35 am
You probably have your NS6 INPUT SELECTORS to LINE https://virtualdj.com/manuals/hardware/numark/ns6/controls/mixer.html
geposted Mon 10 Jul 17 @ 10:14 am
Any updates? i had this happen to me while trying to use a pioneer ddj-sz.
i didnt press any buttons to make it happen
How do i reverse it?
geposted Sat 09 Jun 18 @ 5:15 am
I have a keyboard key (ctrl+m) mapped to simply "mute" which toggles mute on and off
Then if I accidently mess with my connections on one of my controllers causing the automatic muting, I can unmute by simply clicking the keyboard
geposted Sat 09 Jun 18 @ 6:32 am
Set the inputs of your channels to USB on top of SZ
geposted Sat 09 Jun 18 @ 12:10 pm
if some one has the problem that one channel is muted...you need to check the usb/line switches...I had that problem until I check does switches one of them it was on usb B and i use on usb A...I hope that help..have a great day!!
geposted Mon 21 Dec 20 @ 2:52 am
my dumb self once turned the filter on all the way muting everything . took 5 min to figure it out.
geposted Tue 22 Dec 20 @ 5:54 pm
geposted Mon 12 Apr 21 @ 6:47 am
nazclass wrote :
Check your controller input switches
geposted Mon 12 Apr 21 @ 7:02 am
or map a custom button to "mute"
would be fine it can say nothing either. This "MUTE - " in title is weird
geposted Mon 12 Apr 21 @ 7:17 am
Hello, i have a Problem with "mute" too. I there somebody who speaks german?
Translate with google:
Hello, I have a problem with my audio settings. The two xdj700 and the X1850 are connected to VDJ (win10) via a USB hub.
There is an xdj on channel 1 on the mixer, connected with a chinch cable. Input selection USB.
A 1210 is connected to channel 2, input selection phono.
An xdj is connected to channel 3 with a chinch cable. Input selection USB
A 1210 on channel 4. Phono input selection.
Mixers as well as the xdj are recognized by VDJ.
However, deck 1 (xdj channel 1 on the mixer) is set to mute.
The second xdj on deck 2 (channel 3 on the mixer) works.
I only get mute on deck 1 when I set channel 2 on the mixer (phono) to USB. The level meter is still on channel 1.
What am I doing wrong, can someone help me?
Thanks very much
Torsten
Thanks very much
Torsten
geposted Sat 04 Sep 21 @ 6:07 pm
