Hie my Virtual Dj 8.2 is not showing my serato crates..Help Pliz
geposted Fri 14 Jul 17 @ 12:09 pm
It should be inside the "Local Music" folder (if you are using a recent Build) along with iTunes folder etc.
If not there, then check if the "SeratoFolder" setting from VirtualDJ Settings-->OPTIONS tab has the correct folder of your Serato crates/library.(by default in /Music/_Serato_ folder)
geposted Fri 14 Jul 17 @ 10:13 pm
NEED HELP PLEASE IAM SEEING OLDER CRATES THE NEW ONE I BUILD IN SERATO I CANT FIND
geposted Tue 24 Jul 18 @ 10:10 am
