They will be working fine till near the end of my set each time.
https://www.youtube.com/watch?v=VB25mW5T43U
Hardware:
CDJ400's x2
DJX750
Macbook Pro (i7,16GB)
Software:
Virtual DJ 8.2
Thank you in advance
Hardware:
CDJ400's x2
DJX750
Software:
Virtual DJ 8.2
geposted Sat 22 Jul 17 @ 10:22 am
You already posted about this 6 days ago.
https://virtualdj.com/forums/218808/VirtualDJ_8_2_Technical_Support/Scratch_jumping_on_CDJ400_s_as_controllers_on_Mac__(VDJ_8_2).html
geposted Sat 22 Jul 17 @ 1:45 pm
Hardware:
CDJ400's x2
DJX750
Software:
Virtual DJ 8.2
Hardware:
CDJ400's x2
DJX750
Software:
Virtual DJ 8.2
You got something on your search buttons. Some kind of liquid got in there. Pull the player apart and clean the contacts.
I had the something happen with my CDJ 850's.
Well I think that could be the problem but Id check the search buttons for anything because to me it looks like something is making it advance.....
geposted Sat 22 Jul 17 @ 2:30 pm
Hardware:
CDJ400's x2
DJX750
Software:
Virtual DJ 8.2
Hardware:
CDJ400's x2
DJX750
Software:
Virtual DJ 8.2
Its strange cause it only happens when I'm using the jog. Checked the controller signals and its only picking up job movement. Could it be the fact I'm having to plug my mixer into the venues DDJ-SX as a line in?
Only at the venue once a week so its hard to test. :/
geposted Sun 23 Jul 17 @ 4:12 pm
Please use the link to the first post on this issue, to continue this conversation, thank you.
Locked as duplicate by AMAHM
geposted Fri 04 Aug 17 @ 5:38 am
