Topic: Visual indicator in skin?
Hello,
I mapped a button on my NS7 to enable/disable the crossfader. Is there a way to have a visual indicator on the skin that shows me its status? I have the photoshop skills to modify the skin if necessary, just looking for some guidance as to where to start.
Thanks!
geposted Sat 29 Jul 17 @ 3:45 am
you can take a look at a skin done by me (The thing)
https://virtualdj.com/plugins/download.php?addonid=80404&platform=pc
https://virtualdj.com/plugins/download.php?addonid=80404&platform=mac
I've done this with a little menu, so you can change the cf to different modi. This is displayed as a small text:
Modifikation to do in the xml:
<menu >
<tooltip>CF-Options</tooltip>
<size width="172" height="12"/>
<pos x="+0" y="-18"/>
<item text="CROSSFADER-CURVE" action="nothing" />
<item text="Full" action="crossfader_curve 'full'" check="crossfader_curve 'full'" />
<item text="Smooth" action="crossfader_curve 'smooth'" check="crossfader_curve 'smooth'" />
<item text="Cut" action="crossfader_curve 'cut'" check="crossfader_curve 'cut'" />
<item text="Scratch" action="crossfader_curve 'scratch'" check="crossfader_curve 'scratch'" />
<item text="Disabled" action="crossfader_curve 'disabled'" check="crossfader_curve 'disabled'" />
<item text="Hamster (reversed)" action="crossfader_hamster" check="crossfader_hamster" />
</menu>
<textzone >
<Tooltip>CF-Modus</Tooltip>
<up x="+0" y="+0"/>
<text size="12" color="#908F8D" weight="bold" align="center" action="crossfader_curve 'full' ? get_text 'FULL' : crossfader_curve 'smooth' ? get_text 'SMOOTH' : crossfader_curve 'scratch' ? get_text 'SCRATCH' : crossfader_curve 'cut' ? get_text 'CUT' : crossfader_curve 'disabled' ? get_text 'DISABLED' : get_text 'USER'"/>
</textzone>
Take care with the positions. Good luck ;o)
If you are using a skin with Custom Buttons (like the default ones), you can map one of them as ..
crossfader_disable
The custom button will be ON if crossfader is disabled
