Hey my virtual dj 8 when i hit the "pitch reset" it goes back to zero like a snap. It used to gradually slide back to the correct pitch. How do I correct this? I want the gradual pitch to go back to the correct bpm. Thank you
geposted Sat 05 Aug 17 @ 4:50 pm
Single click reverts pitch to zero gradually, double click makes it instant, yet to test if there's a bug but that's the way it was.
geposted Sat 05 Aug 17 @ 8:19 pm
seems to be working fine here
maybe he is double clicking it by accident
if you need to be slower then default you can always map a button to pitch_reset 10%
the percent number changes the speed .. but if u click twice the button it will still be instant.
geposted Sat 05 Aug 17 @ 9:01 pm
I appreciate the responses. I am single clicking and double clicking and it is still going back instantly. Is there any other setting that needs to be adjusted? Thank you
geposted Sat 05 Aug 17 @ 10:50 pm
Check your setting in Audio/PitchResetSpeed. MayBe this helps
geposted Sun 06 Aug 17 @ 12:07 am
Check pitchResetSpeed 0 = slowest 100 = fastest -- even on fastest seems ok
Check pitchRange a value of 1 appears to be instant - think default is 12
geposted Sun 06 Aug 17 @ 12:23 am
It depends on the code in whichever skin he's using (he hasn't said).
There are two verbs. pitch_reset and pitch_zero. The first is the gradual one (default 1% per sec). The second is the instant one.
If his skin has only pitch_zero coded to the button, it will always be instant.
geposted Sun 06 Aug 17 @ 9:25 am
try pitchResetSpeed, mine is @ 1.000000
geposted Sun 06 Aug 17 @ 11:28 am
This is correct ... In settings ... Options ... All Settings ... Audio ... PichResetSpeed ... mine is at 2
geposted Sun 06 Aug 17 @ 8:19 pm
