Hi All,
I've written out a script that is meant to do as described below. This it mostly does, but for some reason the repeat commands do not stop themselves once the script is completed and then the two scripts (one to increase volume and one to decrease) effectively compete with each other. Either that or one of the scripts is being constantly started and stopped.
The code is meant to (sequentially)
1) Fade down the level of deck 2 to 0% (from 50%) and then pause the deck
2) Play deck 1
3) Stop deck 1, play deck 2 and then fade deck 2 back up to 50% again
The interesting part is that each section of the script works on its own - I tested it this way initially - and if you go through the stages, it works the first time but not the others.
The code is here:
I've tried every option I can think of with various extra "repeat_stop" commands included but none of it seemed to make a different - a restart of VDJ was always needed to stop the scripts from running.
Thanks,
Sam
2) Play deck 1
The code is here:
var_equal $quiz 1 ? repeat_start_instant 'quiz1' 50ms & deck 2 level 0% ? deck 2 pause & repeat_stop 'quiz1' & set $quiz 2 : deck 2 level -2.5% :
var_equal $quiz 2 ? deck 1 play & set $quiz 3 :
var_equal $quiz 3 ? deck 2 play & deck 1 stop & repeat_start_instant 'quiz2' 50ms & deck 2 level 50% ? repeat_stop 'quiz2' & set $quiz 1 : deck 2 level +2.5% :
nothing
Thanks,
Sam
geposted Wed 23 Aug 17 @ 1:54 pm
