Topic: Broadcasting / LiveStreaming Video Mixes - Page: 1
Hi all,
I have used VDJ to live-broadcast audio, but now I would like to livestream my video mixes. There doesn't seem to be an option built-in to do this in the VDJ application.
I'm primarily interested in sending my mixes to Periscope, Twitch or Facebook Live.
I suppose I would need livestreaming software that does screen-capture for the video. Can anyone recommend something?
Then there's the issue of audio. I'll be livestreaming from a nightclub, so the audio needs to go out of my controller to the club, but this inherently prevents it from being captured by the streaming software. Does anyone know a way?
I'm on a 2016 MacBook Pro (the one with the USB-C ports), by the way.
Thanks in advance!
geposted Sun 27 Aug 17 @ 7:37 pm
here is what i use free and very effective for video broadcasting to any platform
https://obsproject.com/
you will need to use the 32bit version to broadcast VDJ video
Yes, OBS is probably gonna be your best option on the MAC side.
I use it all the time, seems to have a lower overhead then VDJ itself.
i take back what i said about 32bit version on mac gona need 64bit version
Thanks for the replies you guys. I have tried OBS and I can broadcast the video just fine. But there's no audio to it, even when using system audio capture.
Keep in mind I'm using a controller which has to push audio out to the club (this is the priority over streaming), so I suspect the master output from that controller is never captured by the OBS driver. I have tried the trial version of Wirecast and it's the same story.
How do you get your master-audio on to the stream?
Thanks!
(As a side-note, one thing I like about Wirecast is it can broadcast multiple places simultaneously. I can do Facebook Live AND Periscope all at once)
In the OBS settings there should be a location to select your audio device. Ensure your controllers sound card is selected.
send a output either Booth or master to the input of your internal sound card then set that as a input in OBS :-)
that's how I handle it
you may need a spliter if you controller or audio interface only has master output .... also if you connect to a house mixer it may have a tape out you can use to input to the internal soundcard,
Thanks guys, I'm on a 2016 MacBook Pro - The controller does not show up as an output. On Windows I believe they show up as ASIO devices, but here on Mac, OBS and Wirecast only show the onboard microphone as audio devices.
The laptop also does not have any audio input hardware other than the onboard mic.
Any suggestions?
Found a software-only workaround!
If you go to your VDJ Audio Options, you can add a NEW output. Set it to "Master" and then select "Built-in Output."
This will add an additional copy of the master-output going over your MacBook's speakers, which OBS and WireCast can pick up. If the sound from the MacBook bothers you, you can mute the speakers without affecting the output.
Just make sure you mute the "monitor" from your livestreaming software or you'll end up with a continuous audio loop.
Remember your system is decoding video with VirtualDJ at the same time as encoding audio and video to stream with OBS, so you may need to test the video stream at low quality (resolution and bitrate) in order to not overload the GPU and prevent video freezes.
i broadcast 720p no problem with my 10 year old i7 and a amd 480 video card
OBS is very good with resources .. i would say upload bandwidth will limit your more then the GPU or CPU will.
I'm running 720p video and using Wirecast to simultaneously encode streams for Periscope, Facebook Live and also a separate copy encoded to disk - That's three encoding streams plus mixing and I'm only at 60% cpu. Granted I'm running a 2016 i7 Skylake maxed-out MacBook Pro so I wouldn't necessarily recommend this on lower hardware.
The problem I'm having, like WickedMix said, is bandwidth. I've got about 1 mbps shared with a whole building and the streams suffer from dropouts.
I'm trying to get my video output on virtual dj 8 to appear in my obs I have gone in to the source and clicked on window captures and video captures but I never see the virtual dj video output pop up can someone tell me how to get this right thank you
to make it work on windows run 32bit obs
on mac 64bit obs
Has anyone else had trouble with getting shut down for copyright or is it just me? I thought music videos were made for public viewing?
Nonsense. Music videos contain copyrighted material. You can't just do what you want with them.
Even if you've bought them (I assume you have) that only gives you the right to play them - in a licensed venue, if you're playing to the public. It doesn't give you the right to broadcast them.
I buy every video I own yet I remix on the fly using controller functions (ie Beat Grid, Scratchs and Loops along with various other effects) , so therefore Im changing the original remix of other DJs. I understand the copyright stuff but my question is why have this feature to broadcast live if its gonna get shut down each and every time? I am not one to sit and recreate using ableton or other software because I am just to busy. I would like to use this feature but I guess Im missing something in the translation of its usefulness to average DJ playing gigs whether its club or parties or whatever. I was under the impression that this situation was being worked out between Atomix and Facebook. Just wondering what or how to use this function for normal applications. Any ideas or help would be greatly appreciated.
Thank you @christianwheel-that workaround adding an additional output is what fixed it for me, too!
DUDE THAT IS BRILLIANT! i just added three cams and made ten templates, Everyone needs to see this thing. I had no idea it existed. i found a lot of cool videos on YouTube for it.
95%
