Need Help with deleting Missing Files that are in the the BLUE I-Tunes Folder. But when I search for one of the it doesn't come plus the files are not in the i-Tunes folder under Music>i-Tunes> I-Tunes Media ect.
Also they are labeled with a music note icon but the names of them are video file names. So confused.
geposted Tue 29 Aug 17 @ 11:40 pm
The problem is not related to VDJ.
Use iTunes to remove the missing files from its database, then when you run VDJ again, it will read the corrected iTunes database.
geposted Wed 30 Aug 17 @ 8:41 am
Thought I tired that but I guess I didn't, thanks it worked.
geposted Wed 30 Aug 17 @ 5:45 pm
