Hi all,
Working with a new venue whose video projector erroneously shows a "mirrored" version of the video feed. They seem to have no interest in fixing it, so I'm looking for an effect that can mirror-image / flip the video as it goes out to the screen.
Any sort of software solution to do this?
Thanks!
Thanks!
geposted Fri 01 Sep 17 @ 11:31 am
if the projector has a remote (and isn't ancient) you could probably change it through a menu setting. other than that i know i can flip an image horizontally with TellyVisuals but not sure if that's with the basic version or one of the fancier versions.
geposted Fri 01 Sep 17 @ 11:57 am
I think you can flip images in TellyVisuals as well.
geposted Fri 01 Sep 17 @ 12:16 pm
TellyVisuals can flip the image horizontally but it's not really a 'true' mirror image. and if you're using scrolling text on screen with tellyvisuals it's still going to be mirrored with the projector showing it wrong
geposted Fri 01 Sep 17 @ 12:25 pm
I'm on Mac, so TellyVisuals isn't an option.
The projector is ancient and it's apparently always been this way. The owner doesn't want to let me mess with it. At the end of the day it's not that big a deal I guess, it's just weird with all the text flipped. It feels like a "mirror" or "flip" plugin would be a given, but after going through the downloads area, I guess not.
geposted Fri 01 Sep 17 @ 12:30 pm
Hahahaa! Yeah sorry @Wild
geposted Fri 01 Sep 17 @ 1:21 pm
Just to set the record straight, this is using a copy of TV to flip the VDJ display horizontal and vertically. A normal TV layout is running underneath. So just made a copy of TellyVisuals.dll and called it flipped.dll. The flipped.dll has a layout with no panels. The background of the layout for flipped.dll is set to use the VDJ video as it's image and set to flip horizontally and vertically. Could have been set to just flip horizontally (mirrored) and not vertically or any combination.
geposted Fri 01 Sep 17 @ 2:31 pm
Showing all variations of flip at the same time with a video playing and rotating (center panel).
geposted Fri 01 Sep 17 @ 3:33 pm
Why not just change the settings on the projector (if you can reach it or use the remote) !?
geposted Fri 01 Sep 17 @ 5:14 pm
Is this util any use (at the bottom of the page)?
https://www.freetelepromptersoftware.com/mac/
geposted Fri 01 Sep 17 @ 5:33 pm
GroovinDJ I found that yesterday! And while the utility works, it fails miserably for VDJ. It flips the ui of VDJ but leaves the video display as normal, haha. I literally LOL'd when I saw the effect.
geposted Sat 02 Sep 17 @ 4:34 pm
Why dont you just tell your boss that you dont do videos, if they dont help you to setup the projector correct?
geposted Sat 02 Sep 17 @ 5:47 pm
