Hi all
Trying to use vdj and broadcast via 'breakaway' software for radio shows.
My question is does anyone know if possible to use same laptop and configure soundcard/controller so i can hear master out from controller and internally on laptop to breakaway to broadcast?
We had to use booth out as a monitor and
Send master out to another laptop via mic jack to then broadcast through breakaway
Problem with that is 1.you need 2 laptops and 2.cant monitor mic through booth so cant hear if mic is too loud etc.
Hope this makes sense-thanks all in advance
Tom
Tom
geposted Tue 05 Sep 17 @ 3:35 pm
Which Breakaway software?
geposted Wed 06 Sep 17 @ 4:47 am
Hi
Breakaway software is called 'butt 0.1.15'
Regards
Regards
geposted Wed 06 Sep 17 @ 1:48 pm
BwhuD wrote :
Hi
Regards
Regards
I know of no Breakaway software named that...But I do know an open-source software called butt
geposted Fri 08 Sep 17 @ 6:06 pm
Yes thats the one-
Iv managed to get a reading on the level meter in butt now by adding master out in sound settings.
Seems to have solved my problem.
Thanks all the same
Tom
Thanks all the same
Tom
geposted Sat 09 Sep 17 @ 1:26 am
