Hi everyone
It seems whilst I'm using the BPM editoe pressing the play button within it doesn't produce any sound nor doe the metronome button.
Anyone else having the same problem or know how to fix it please?
Thanks
Thanks
geposted Tue 12 Sep 17 @ 10:11 pm
Not having issues here
geposted Wed 13 Sep 17 @ 1:11 pm
You might want to check your sound output settings.
Switch the output to "speaker only" and then try to play from the bpm editor. It should warn you about no headphones configured, but since this is a tool better suited for preparation before a gig, it should be all right.
Just remember to switch output back to "speaker and headphones".
Hope this helps :)
Hope this helps :)
geposted Wed 13 Sep 17 @ 2:02 pm
What he said :-)
The information is in the manual by the way. It's a good idea to read it.
https://virtualdj.com/manuals/virtualdj8/editors/bpmeditor.html
geposted Wed 13 Sep 17 @ 4:57 pm
