vdj wont play a track. when play is press, the track "twitches" but does not play.
received this error after I updated today. please help
geposted Tue 19 Sep 17 @ 6:31 am
message received is no soundcard.
*default
failed to initialize device.
this is new. never happened before. please help
geposted Tue 19 Sep 17 @ 6:33 am
*default
the track shakes in the as if it wants to play but does not initiate.
*default
geposted Tue 19 Sep 17 @ 6:36 am
What conroller are you using?
Sounds like the audio driver can not be loaded or is crashing.
So try the following:
1. Disable the controller as standard audio device in you OS if it is set to standard audio device. Set it to you built-in soundcard instead.
2. check if all USB connections are well in place.
3. With the controller connected and ON, open you ASIO driver panel and check if the programm can see you controller.
4. Check if VDJ can see you controller.
geposted Tue 19 Sep 17 @ 7:26 am
vdj 8.2 has a problem with the waveform on 4 decks when the waveform is set to default it does not show clear but appears more invisible.
geposted Tue 19 Sep 17 @ 9:46 am
