Hi
Can any one help me with my VMS5 setup.
Thanks
Graham
Thanks
Graham
geposted Mon 25 Sep 17 @ 11:58 am
Hi,
what's your problem with setup VMS5?
geposted Mon 25 Sep 17 @ 12:28 pm
Did you checked the manual already ?
https://virtualdj.com/manuals/hardware/americanaudio/vms5.html
geposted Mon 25 Sep 17 @ 3:11 pm
KleinerEisbaer666 wrote :
Hi,
Hi thanks for your reply.
I have virtualdj 8 le for my AAVMS5. I need to know the audio set up settings.
I want channel 1 for line input, channel 2 & 3 for laptop and channel 4 for line input.
I also want to be able to use the VMS5 mixer.
Thanks for any help you can give.
Graham.
geposted Mon 09 Oct 17 @ 2:46 pm
Did you read the post before your last post, on this page?
geposted Tue 10 Oct 17 @ 12:47 am
Graham.
Hi,
Graham.
Pretty sure with the LE license all you can do is the default audio setup for your device which probably doesn't include inputs.
geposted Tue 10 Oct 17 @ 1:12 am
Hi does anyone know how to set the VMS5.0 so you can control the Bass and Treble with the midilog instead of it auto setting?
geposted Wed 20 Dec 17 @ 2:53 pm
