Oeps.....
I try to auto-update from b.3967 to 3978, but get message "auto update failed". Retray a copple of times but effect is the same.
Download b.3978 and installation by hand no problem at all.
geposted Tue 07 Nov 17 @ 12:17 pm
The fix is only in 3978, so auto-update will only work again starting from that version.
geposted Tue 07 Nov 17 @ 2:04 pm
Thanks fo the info, you guys are great.
geposted Tue 07 Nov 17 @ 3:15 pm
Good news! Thank you for the fix.
geposted Wed 08 Nov 17 @ 11:27 pm
Problem is still there for me on one of my PC's. Even when updating from more recent versions
geposted Fri 24 Nov 17 @ 3:38 pm
Solved here, for a while I thought it was just me.
geposted Sat 25 Nov 17 @ 6:18 pm
probably better say what build u have an issue with cause it was just fixed with an early access build.
geposted Sat 25 Nov 17 @ 6:41 pm
and the early access build number is?
geposted Mon 27 Nov 17 @ 3:12 am
geposted Mon 27 Nov 17 @ 10:17 am
Seeing the issue again I am on V8.2 b4002 And the application asks me if I want to update. acs like it is downloading and then does nothing. If I manually download the build and install will it overwrite any of my settings?
geposted Wed 06 Dec 17 @ 9:56 pm
Seeing the issue again I am on V8.2 b4002 And the application asks me if I want to update. acs like it is downloading and then does nothing. If I manually download the build and install will it overwrite any of my settings? Sorry about the double post not sure what happened.
geposted Wed 06 Dec 17 @ 9:57 pm
4011 (2017-12-01) UPDATE the sideview,info.sidelist when moving them now the waveform is not smooth any more kind of jittery some.
geposted Thu 07 Dec 17 @ 3:29 am
I tried what I did last time and turned off the anti-virus and ran Virtual DJ 8 as administrator and that is not working this time either. Any thoughts?
geposted Thu 07 Dec 17 @ 1:04 pm
RCBAudio wrote :
No, it won'tIf I manually download the build and install will it overwrite any of my settings? .
Delete the "ready" file from VirtualDJ/Cache folder, open VirtualDJ and try again.
geposted Thu 07 Dec 17 @ 1:08 pm
Thanks for the suggestions.
OK tried that. Deleted the "ready" file from cache and opened VDJ again. Same thing it informs me of the update; downloads the update and then nothing. The "ready" file is regenerated in the cache folder.
geposted Thu 07 Dec 17 @ 1:32 pm
