Hey Guys,
Anyone have or know if the new Pioneer XDJ-RX2 is mapped or ready for VDJ? I am on 8.2 Build 3936. And using Mac Version Yosemite 10.10.5 What are the steps to make sure i do the correct setup? Thank you
geposted Tue 17 Oct 17 @ 5:57 pm
The XDJ-RX2 is not yet supported.
http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
It is in our To-Do List but really no ETA can be provided at this moment.
geposted Tue 17 Oct 17 @ 6:14 pm
Can it be still used with VDJ? or connected the same way the RX was?
geposted Tue 17 Oct 17 @ 6:35 pm
Official support will be for version 8 only.
Both VirtualDJ 7 and 8 support "Simple MIDI" , meaning that you will be able to use it as sound card and map its buttons and faders quite easily. However, LEDs, VU meters (probably jogs) and certainly the Display, require a more in depth definition.
geposted Tue 17 Oct 17 @ 6:49 pm
Thank you! Well hope it's going to be soon. Since this hit the stores last week & i am sure a lot of pioneer lovers will be looking to map this and have everything working. :)
geposted Tue 17 Oct 17 @ 7:40 pm
I suppose its worth checking to see if the old RX test mapping that was available before official support, if that works?
It may get some up and running, albeit minus all the features, but at least its a start.
geposted Thu 19 Oct 17 @ 1:07 pm
No, it won't work.
geposted Thu 19 Oct 17 @ 4:54 pm
Oh well back to the drawing board I suppose
geposted Thu 19 Oct 17 @ 4:56 pm
Do you actually have the controller ?
geposted Thu 19 Oct 17 @ 5:11 pm
I do have it, I have the latest firmware for it, I am on the latest build of VDJ and nothing works. I have it in Midi mode and not cue, play, Wish the software would detect it when it is connected. What is the easiest loophole around this and get it working. I have gigs coming up and need this working and then i can worry about the touch screen etc,
geposted Thu 19 Oct 17 @ 6:37 pm
Send me a PM
geposted Thu 19 Oct 17 @ 7:28 pm
So anyone come up with a mapping and solution to this new controller?? Holidays are here soon and i would like to use my VDJ and this asap. :(
geposted Mon 23 Oct 17 @ 5:11 am
Staying in contact with PhantomDeejay, and helping Atomix out, is probably the fastest way to get the controller supported
For everything to work on it, they probably need to reverse engineer it first, because Pioneer locks it to only specific software.
For the original XDJ-RX that took about a year
geposted Mon 23 Oct 17 @ 5:26 am
geposted Mon 23 Oct 17 @ 9:11 am
PhantomDeejay wrote :
http://www.virtualdj.com/forums/220410/Hardware_Technical_Support/Pioneer_XDJ-RX2_Unofficial_Support.html
See! It worked
geposted Mon 23 Oct 17 @ 10:39 am
Hi guys, any update or somewhat of a teaser on the RX2 mapping ?
geposted Mon 30 Oct 17 @ 6:48 pm
There is a link to a temporary mapping (without support for the screen) posted to posts above your post
geposted Mon 30 Oct 17 @ 8:20 pm
I like your post, where you posted about the post above his post. :-)
geposted Mon 30 Oct 17 @ 10:05 pm
I like your post, where you posted about the post above his post. :-).......
In your post where you refer to his post about posting in the post above his post, is incorrect, it was posted in the post prior to the post before the above post and I am posting this to correct that post by the poster
geposted Mon 30 Oct 17 @ 10:25 pm
Gentlemen, please... Get back on track!
Thank you!
Thank you!
geposted Tue 31 Oct 17 @ 6:42 am
