Hello dear VDJ community.
I have the following setup ...
2x Stanton S.150
2x VirtualDJ8 Timecode Vinyl from the VDJ-Shop
1x Allen & Heath Xone 22
1x Hercules DJ Trim
and of course VDJ8
everything runs on a MacBook Pro (late 2013) with macOS Sierra
and the following problem ...
VDJ8 has been reinstalled. Timecodes calibrated and everything works.
If I now add a song in DECK A , then the pitch display jumps to 0.3% or a similarly small value from the beginning.
If I match the track in the DECK B, then the BPM jumps and the track runs faster forward extremely audibly.
I haven't this problem with VDJ7 and the old Numark Timecodes. In VDJ 7 the mixes are very precise. But I would like to use version 8.
BPM autoMatch is set to NO.
Is there the possibility to adjust the sensitivity of the speed recognition?
I am already afraid of the next gig, because my crossing may currently only take a maximum of 10 seconds.
Maybe someone has an idea.
best regards
Andre
2x Stanton S.150
1x Hercules DJ Trim
and of course VDJ8
best regards
Andre
geposted Thu 19 Oct 17 @ 8:03 am
I have this same issue with 3967 & XDJRX with latest full midi firmware
I get a quick Downloading messege on the GUI & the XDJ decks start flashing and either one of the tracks will jump up .5 - 2 bpm.
Ever since full midi mode has been implimented it seems.
I also noticed the Controllers mapping window jumps through 5 or 6 different mapping commands during the “downloading flashing sequence/issue”.
[ONINIT:PITCH:SPEED_ADJ:INPUT_HW:DECK:GAIN:EQ_HIGH/MID/LOW]
I tried to figure out and disable them few commends but it hasnt worked.
Disabling auto bpm, key, smart etc has not help.... only thing that stops this issue is disabling/deleting the pitch/tempo slider all together. But im not 100 on that either.
It must be somthing to do with full midi support and the hw/sw pitch tempo slider differences or a change on the fader to master...?
Any help please, i will so appreciate it.
Surface I5, 8GB ram. Windows 8.1
Vdj 3967. Silver sleek skin
Xdjrx 2.21 firmware
Xdjrx 2.21 firmware
geposted Wed 22 Nov 17 @ 5:11 am
